when I reboot will I lose my contacts
same asa question title
Ist dies eine gute Frage?
Scott Miller, Do you mean if you factory/hard reset(1st link below), if you do then yes you will loose all data that was stored on the phone that was not previously save to a different device, SD card,etc.. Check the link below for more info.. There is also a soft reset procedure at the (2nd link) which you will not loose your info./data when performing. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
If your talking about turning your phone off and back on again, No that would be really stupid. If your talking about erasing everything on your phone, yes. If you are erasing everything, i suggest you back up the contacts or even type or write them all down to add them back later.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 80
