Zum Hauptinhalt wechseln
A1706 / EMC 3071 - herausgekommen im November 2016. Dieses 13" Macbook Pro führt die OLED Touch Bar ein. Es bietet einen Dual-Core "Skylake" Intel Core i5 CPU und vier Thunderbolt 3 Ports.
239 Fragen Alle anzeigen
Display Assembly Replacement Repairability
I was wondering how difficult is was to remove and re-insatll a new Display Assembly on the new MacBook Pro Touch bar. I noticed hinges in the middle of the screen. Do you have to do anything with the Touch Bar in order to remove the Display>
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Right now we don't have any guides prepped as the system is just to new and parts are just not available yet.
Depending on what happened it might be covered under warranty. Can you tell us a bit more here?
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Just trying to be prepared. We fix apple computers on a daily basis. I have had a couple calls about folks dropping thier Touch bar macs and smashing the LCD which obviously the entire assembly needs to be replaced. Watching the Teardown video i did not see the Display was removed. Was just seeing if iFixit ever removed the display before and if so, did they have to disassemble the touch bar at all to get to the hinges holding the Display to the Top Case.
von
More likely they yanked the USB-C power cord pulling the system to the floor ;-}
A friend of mine who works for Apple told me he has already seen 4 systems messed up because there's no MagSafe anymore. They're becoming expensive paperweights.
von
For reference: How do I replace my screen on my MacBook Pro? You're not the only one ;-{
von
VERY challenging and parts are not affordable, I think I counted 30 screws for the display touch bar area, total nightmare
von
Antwort hinzufügen
Store Manager wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 665
