Zum Hauptinhalt wechseln
Die zweite Generation des Mazda 3, auch bekannt als der Mazda3 BL und Mazda Axela, Limousine und Fließheck-Serie von Mazda.
10 Fragen Alle anzeigen
Revs too high after service
After taking the car for a second service to reduce the revs I still find them higher than when I bought it. The mechanic said all he did was reset the computer. Is there a way I can change the computer settings or how would I go about changing the revs?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
countparas, You can not change the cars computer settings with out special scanner/software/knowledge as normally found at a dealership or well equipped shop.
Ask the dealer ship/shop to show you the cars idle speed specifications cold/warm(operating temp.), if idle speed is in the parameters should probably not adjust further. If not in parameters they should correct the issue. Whether by adjustment/faulty sensor, vacuum leak,throttle body sticking/dirty or having to change program in computer. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
Bewertung 4
Your mechanic needs to set the rev limiter on the computer.
Bewertung 1
Antwort hinzufügen
countparas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 1,145
