Zum Hauptinhalt wechseln
Samsung WB1100F is a digital camera with the ergonomic feel of a traditional DSLR, but also the ease of use of a point-and-shoot compact. The WB1100F has a 16.2MP CCD sensor with a sensitivity range of ISO80-3200 and a 35x optical zoom lens with a focal range equivalent to 25-875mm (in 35mm-camera terms). The WB1100F was released in early 2014.
23 Fragen Alle anzeigen
My cable plugged into the camera will not charge or transfer photos.
When I plug my cable into my Samsung wb1100F camera the light may come on for a second and then turn off. I wiggle the cable and once in awhile it will light. It acts like
it just doesn't make a good connection.
Can this be repaired?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
beadyp , Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the camera to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board if you would like to attempt. If not wanting to do the repair yourself have a good camera/computer/cell phone repair shop have a look and estimate repair. Good luck.
Samsung WB1100F Motherboard Replacement
https://www.youtube.com/watch?v=rTim6FIJ...
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
beadyp wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 250
