Zum Hauptinhalt wechseln
Das Galaxy S6 ist das neue Flagschiff der Galaxy-Linie. Es wurde im März 2015 angekündigt, Verkaufsstart war am 10. April. Die Version mit dem gewölbten Bildschirm ist unter Galaxy S6 Edge bekannt.
487 Fragen Alle anzeigen
Phone Dropped, screen not working but LED is flashing (blue to white)
Hello, as obvious from the title I dropped my Galaxy S6 and the screen is black. Turning the phone one just gets me a flashing LED and nothing else. The phone is still in the warranty period. If I sent it for servicing is there any way for them to know that I actually dropped my phone?
Is there anything inside the phone that can break or shatter from a meter-long fall?
Or is the screen broken because something is misplaced which shouldn't be much of a big deal?
Thanks a lot
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
elchinaxundov, Check the link below and play the vid., as the Samsung phones are subjected to drop test and from 1 meter should have survived. Return under warranty for repair/replacement/refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.slashgear.com/samsung-does-i...
War diese Antwort hilfreich?
Bewertung 4
5 Kommentare:
elchinaxundov , at this link $180.00 Recommended Retail Pricing for Screen Replacements.
http://www.samsung.com/au/support/screen...
von
Thanks for the tips. The fall was DEFINITELY below 1 m. And assuming that Samsung decides that the damage was done by fall and would not be covered how much should I approximately expect to pay in order to get a screen replacement?
von
Wow, that's like more than half the cost of a phone. I'll see what I can do :)
von
elchinaxundov, thanks for replying back, good luck with your S6.
von
Thanks :) I hope it will work out.
von
Hi yes this is a AMOLED break its very odvious when put under t light tests or high frequency light a common test done by samsung on the display to determine if it was physical damage that caused the phone to quit working it needs a Screen Replacment.
Bewertung 2
4 Kommentare:
AMOLED vs LCD: differences explained
http://www.androidauthority.com/amoled-v...
von
Just curious, if a screen stops working because of a fall, does that mean something is irreversibly wrong with it that it needs to be replaced or does the fall make something displaced inside that can be fixed without replacement?
von
Just A screen replacment is commonly needed drops can lead to other issues at this point screen replacement is the best option
von
I see, then I'll probably won't push my luck and go for the screen replacement. Thanks for the advice :)
von
Antwort hinzufügen
elchinaxundov wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 3,324
