Zum Hauptinhalt wechseln
MacBook Pro 17" logic board replacement
Hi there,
I've a MacBook 17" Core Duo A1151 with a bad GPU, so I need to change the logic board entirely. Can I replace it with another from an newer Macbook Pro 17" Core2Duo A1212 ?
Many thanx to any answers!
Dario.
Ciao a tutti,
ho un MacBook 17" Core Duo (A1151) del 2006 e, per un problema alla GPU, devo sostituire la scheda logica. Chiedo se una proveniente da un MacBook Pro 17" Core2Duo (A1212) e sempre del 2006, fosse compatibile con la mia macchina.
Un grazie a qualsiasi risposta!
Dario.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Fortunately I've found a Apple assistance centre who can replace the old GPU with a new one and the work isnt much expensive.
Thank you!
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Ciao! quanto e´ costato il cambio della scheda logica all´assistenza apple?
Hi, how much was the price for the sostitution?
von
Avatech, 185 euro compresi ritiro a domicilio e spedizione.
von
Hilfreichste Antwort
Unfortunately, Apple changed several of the internal connectors between these two models, so the logic boards are not interchangeable. For example, the connectors for the fans are different.
Bewertung 1
Antwort hinzufügen
Dario wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 246
