Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
Earpiece speaker missing mesh
I converted my iPhone 4 to white using parts from Amazon.com. I later noticed 2 things that I was wondering if anyone has had experience with.
1. The mesh behind the speaker slit is missing.
2. Photos taken with the flash are overexposed, bleached blue and hazy.
Any shared knowledge around these issues?
Has anyone here purchased the white parts from ifixit and been successful? As in, not experienced these issues?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
It did have the flash diffuser, I just failed to remove the plastic. Dee dee dee.
I have found a parts supplier that includes the mesh piece so I don't need to remove it from the old one. www.applepartsstore.com. They are located in Utah. I placed my first order with them yesterday. Will post back when my order arrives in case anyone else is looking for good parts.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
you could have removed the old mesh from the original display or bought a new one for the repair.
for the photo problem, make sure there isnt any protective plastic covering the lens area. if there is you were suppose to peal it off before installation.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks Matt. It was just as you said for both issues.
von
you need to remove the mesh from the old lcd and put onto your new lcd. you may also need some adhesive to stick it on there.
also the back plate, you are probably missing the flash diffuser.
Bewertung 0
Antwort hinzufügen
Brady wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 3,980
