Zum Hauptinhalt wechseln
Standventilator ohne Flügel von Dyson.
18 Fragen Alle anzeigen
fan not oscillating back and forth
What's wrong and how do I fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I have the problem too, it is not oscillating.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
mkoch, If it is new, did you remove the tape, from the lower base body split section, if not remove before turning on any more or damage to internal gear could occur. Recheck that the fan is still assembled correctly and locked in correct position. Install new batteries in remote and try. If all looks good and still under warranty return for repair/replacement/refund as there may internal damage to oscillating gear. See below links, your manual and Dyson support site.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/888752...
https://www.dyson.com/support/am02/am02-...
War diese Antwort hilfreich?
Bewertung 7
2 Kommentare:
So simple, duh, I forgot the tape. But it doesn’t show that in the setup instructions.
von
I need help in opening the remote. I've had three people look @ this remote. Pls help!!!!!!!!!!!!
von
It would be more helpful if the tape that has to be removed was an obviously different colour rather than white the same as the oscilating plinth - ie ... make it idiot proof - it took me a while to work it out as well lol
Bewertung 0
Antwort hinzufügen
mkoch wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 32
Letzte 30 Tage: 120
Insgesamt: 45,892
