Zum Hauptinhalt wechseln
Released in 2015, this laptop can be identified by the model number ba0709dx. Repair of this device requires screwdrivers and prying tools.
7 Fragen Alle anzeigen
in trying to learn how to disassemble my Laptop
I recently purchased an Elgato HD 60 and my Xbox was bumped and my computer fell and now my charging port is messed up, or out of alignment, because I can't get the thing to charge. The main problem is that it doesn't go in the port all the way and I tried forcing it which just made like a rubbing on something made of aluminum sound or static kinda sound ..
I just looked inside the port and there seems to be a thin bronze piece connected to the back.
Update (04/13/2017)
Oh, it was my the tip of the jack connected to the charger it broke in the port.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Here is a link to the service manual for your laptop.
On p.63 it details the necessary pre requisites and then the procedure to remove the power connector cable. (this cable has the charge port connected to it - it is regarded as one unit, see image of part in supplier link below)
Also on p.63 is the part number of the power connector cable -732067-001
Here is just one supplier of the part. It is not a recommendation to use them, it is shown just to give an idea of the cost of the part. There are other suppliers that may suit you better. If you search online using the part number only you will get results for other suppliers of the part.
Hopefully this is of some help
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Feeding Logic wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 212
