starter solenoid wiring diagram from battery to solenoid
Craftsman Riding Mower model27011 i need to know how the wiring diagram from battery to solenoid to starter is configured
Ist dies eine gute Frage?
@lawnboy707 verify your complete model number for us. This diagram should work for your mower.
War diese Antwort hilfreich?
I want to know to
@randystarcher you would like to know what :-)? Have you checked the above posted diagram?
@lawnboy707, John, Below you will find the manual and pic's/schematic of how wire's are hooked for starting system, for Model #502270111 CRAFTSMAN Lawn, Riding Mower Rear Engine. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
here is the wiring diagram i found at https://www.searspartsdirect.com/model-n...
In the diagram there are the numbers "1-26". It would be helpful to have the key along with the diagram to help identify what each number correlates to. I.E. number 3 identifies the anchor bolt for the hot wire to the positive battery terminal
@Michael Dodson
If you click on the link provided in the answer above your comment you will get the Sears webpage where it came from.
Under the diagram on the page is a list of the part numbers as shown in the diagram and if you then click on the relevant part i.e. part #1 = Sensor 91031 you will get the part description etc.
Search online using the required part number to find suppliers that suit you best e.g. this supplier is cheaper than Sears (although shipping may be a factor to be aware of depending on your location)
Letzte 24 Stunden: 31
Letzte 7 Tage: 202
Letzte 30 Tage: 912
Insgesamt: 81,576
