Zum Hauptinhalt wechseln
Device repair information and troubleshooting for the HP Pavilion g6 laptop.
Overheating on left hand corner.
After 10 plus minutes left hand corner of machine gets hot. Eventually almost too hot to hold. Fan appears to be going.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi,
Left hand front or rear?
Are the fan vents clogged?
Does the laptop shut down of its' own accord?
Here is a link to the service manual for the laptop.
It will help in the dis-assembly of the laptop so that you can check that the fan is OK and not clogged etc. and also to ascertain where the heat is coming from.
War diese Antwort hilfreich?
Bewertung 6
1 Kommentar:
https://h30434.www3.hp.com/t5/Notebook-S...
yes its the chip with small metal heatsink but not connected to fan. how do you think i can get cooling solution hack for this
von
same here, my fan area is perfectly clean. im blaming the 3rd chip in that area which i dont know what it is. but i havent open case after running it to prove it. hot area is what u rest you left palm. what to do its too hot
Bewertung 0
you can read here for solving
https://www.knowerstech.com/hp-pavilion-...
Bewertung 0
Antwort hinzufügen
Mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 6,593
