What r the differences between g920v motherboard and g920f motherboard
Can I replace my broken g920v 64gb Verizon motherboard to new g920f 32gb motherboard in galaxy s6?
Thx
Ist dies eine gute Frage?
Thx
Should fit, though there will be reception issues due to the charging port antenna pin connectors being in different spots. Resoldering the pins to the correct areas matching to the antenna contacts should fix the problem (for charger port). It's probably going to work fine with just switching the board anyway.
War diese Antwort hilfreich?
Thank u very much!
what about a g920v and a g920t? same deal?
No you cannot change a motherboard like that.
The G920 V is a US Galaxy S6 that is manufactured to support Verizon.
The G920 A/T is a US Galaxy S6 that is manufactured to support ATT and T-Mobile.
The G920 F is an International Galaxy S6 that is manufactured to support International GSM LTE networks.
You will be in a lot of headaches if you swap out a V for an F.
The V has an extra chip for CDMA. Also, the V only supports Verizon LTE bands.
In addition to IMEI, the V has an "ESN" number for Verizon network identification.
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 936
