Zum Hauptinhalt wechseln
Ein 15,4-Zoll Windows XP Laptop, der 2006 von Dell veröffentlicht wurde
displaying the error message
My computer is displaying the error message operating system not found when I turn my computer on and then it shuts down. Why would this be happening
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
This is a question, not an answer. Also it would be doing that because your hard drive is dead or the operating system is corrupt. Take it to your local computer repair shop. They will be able to fix it for you.
von
stacmarie29 I do agree with that it sounds like a HDD failure but I am not convinced you need to take it to a repair shop. Since this questions was converted from an "Answer", we need to know for sure what make and model your computer is.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
stacmarie29 you will have to try and access your BIOS. There you check to see if your harddrive is still recognized. Also, check the boot order and either change it to optical drive or USB and use a booting CD or USB drive to see if you can start your computer in an OS. I would recommend a Live-CD of something like Puppy-Linux. You can run that of a CD and it will allow you to check and see if it can access your HDD and the files on that. If it cannot, than you will most likely have to replace the HDD. Once we know what make and model your computer is, I am sure we can get you to repair it yourself.
War diese Antwort hilfreich?
Bewertung 1
I am missing 12 out of date driver
Bewertung 0
Antwort hinzufügen
stacmarie29 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 354
