Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
unable to charge new battery
After installing my new battery my phone won't charge. I have tried a force restart but nothing works. During the replacement, when I took the battery holder off and removed the battery connection, another component was stuck to the battery holder, It had a small disc at the end of a wire and appeared to fit in a socket receptor adjacent to the screw receptor furthest from the edge of the battery. I replaced this but wonder if it might be broken.
Update (04/24/2017)
The old battery sometimes wouldn't charge if I didnt have the connector in firmly. However, when charged the battery wouldn't hold the charge for more than a couple of hours. When I connect to the charge port now my iphone isn't recognized on my computer so I must have done damage when I changed the battery. The only problem I had was that when I pulled off the battery holder the wire with the connector came with it as well as another wire that was lifted out of it's socket. I don't know what the latter was for but suspect that is the issue.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can you post a picture? Do an edit to your question and include a picture so we can see what it is.
von
Einen Kommentar hinzufügen
2 Antworten
I think you are talking about the cellular data antenna. Even if you damage that it wouldn't stop your phone from starting up. I would try plugging into itunes, you may have to restore it from there.
War diese Antwort hilfreich?
Bewertung 0
Did the phone charge with the old battery? If so, try a known good battery. If not, there is probably something wrong with the charge port or charge circuitry.
Bewertung 0
Antwort hinzufügen
Peter Scott wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 61
