Zum Hauptinhalt wechseln
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
Can I add an HDD 2.5 or SSD?
Hello,
I am looking to buy an XPS 15 (9560), but I would need more memory than 512Gb.
Could I add an internal HDD?
Regards
Ricardo
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
you are asking two questions. or you may be confused on parts. first memory is not the same as a hard drive. so are there two questions or just one?
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Ricardo, it looks as if you can add a 2.5" HDD or SSD. The factory SSDs are in a M.2 or mSATA slot, leaving the HDD bay open for upgrade. You may want to consider a Seagate firecudas SSHD for not much more than the price of a regular HDD.
Hope this helps!
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
This is only possible on the version with the smaller battery. The version with the 97Wh battery has no room for a 2.5" drive.
Source: I own both version
von
yes you can up to 1TB
Bewertung 0
1 Kommentar:
I would like to know where you got this information.
von
Yes you can if you have an FHD model. Consider that you'll need an adapter. You can easily find it online
Bewertung 0
Antwort hinzufügen
ricardo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 8,851
