Zum Hauptinhalt wechseln
Das Kingston HyperX Cloud II Gaming Headset ist ein von Kingston konzipiertes Headset. Dieses Gerät beinhaltet ein Headset, ein abnehmbares Mikrofon und einen Inline-USB-Audio-Controller und ist mit den meisten Geräten kompatibel. Modellnummer: KHX-HSCP-RD
81 Fragen Alle anzeigen
Headset cable broken cannot rewire
So after using the HyperX Cloud 2 for like 7 months I cannot hear anything from the right ear cup.
This happened when I was playing CS:GO.
I played several times with the cable going up in the headband, that's why the cable broke. (Check image)
(It's actually the other cable going up in the headband that broke)
I tried to wire them back and plug it in. It didn't work because the green wire has a special coating ? (Check Image)
(Not the broken wire)
(The broken wire)
Now only the mic and the left ear cup is working, what can I do to fix the wire problem ?
I tried to wire them back together but it didn't work because of the special coating i'm guessing ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You need to strip the coating. I suggest using a lighter to melt it off. I found that works the best. After its stripped, you need to resolder the cables together, which i assume you know how to do.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you so much, i'll try that today.
von
Can you not use the lighter to remove the special coating and wrap them together? The same as using speaker wire or does it have to be soldered?
von
Antwort hinzufügen
musa_a wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 28
Insgesamt: 7,043
