Zum Hauptinhalt wechseln
Die Nikon N80 (auch als F80 bekannt) ist eine 35-mm-Spiegelreflexkamera. Sie wurde im Januar 2000 veröffentlicht und ist an der Modellnummer 1776 zu erkennen.
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Thanks for the tip. I will certainly give it a try.
von
I had been on the guide page, but I didn't notice the repair manual tucked in there.
von
It's a present added after you asked the question
von
Antwort hinzufügen
Eric Zulaski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 26
Insgesamt: 574
