left side speaker not working properly.
It works perfectly fine if the jack is connected. but the left side of the headphone doesn't work while using on wireless.
Ist dies eine gute Frage?
Hi @hanamichhi ,
Does the BT audio cut out when you insert the aux. cable? (the other end of the cable doesn't have to be connected to anything). If so I'm wondering if you might have a faulty aux. input socket or the wiring connected to it
The wiring circuit in a lot of BT speakers, headphones etc. is that the audio from the BT goes through contacts in the aux. input socket to the amp/speakers, which changeover the audio source from the BT to the aux socket when the plug is inserted.
To find out you'll have to open the headphones where the aux socket is and inspect it. The left earphone is connected to the 'tip' connector (and its' associated contacts of the aux socket) Just a thought.
War diese Antwort hilfreich?
@hanamichhi akashshrestha30 , Try this, Go to System Preferences > Sound > Output > Balance ( Set the balance at the middle ), info from link below. If still no improvement perhaps try resetting(link #2) resetting and trouble shooting. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 39,804
3 Kommentare
So, what i did was, plug the audio cable in WHILE bluetooth was still on, and then took out the cable, turned off bluetooth, turned it on then reconnected 8t
von ai zawa
Had the same issue.
This solution worked for me!!
Thank you!!
von Diana
It works, but why does this work and is this permanant?
von cheongedward
