Ipad 2 Wifi turns itself off after battery replacement
Hi, I recently did an Ipad 2 Wifi Digitizer and battery replacement. Initially it seemed everything was working fine, but after 2 or 3 minutes of being powered on it turns itself off. Initially I thought it might have a loose connection to the battery but that is definitely not the case, the board is screwed down ontop of the connector and it restarts just sitting by itself.
Has anyone else seen this before? I ordered a new battery in case this one is defective, can't test it with the original battery because it was damaged during the removal. I'm wondering if the OS forces it to shut off when the battery percentage increases or decreases. The battery does charge up and arrived at 28% and I charged it to around 33% while messing with it. Now I have it manually turned off and charging so it won't force restart itself while plugged in.
Ist dies eine gute Frage?
