Zum Hauptinhalt wechseln
Erste iPad Generation, erhältlich mit WiFi/3G mit 16, 32 oder 64 GB Speicherkapazität.
266 Fragen Alle anzeigen
Can I modify an iPad and increase the memory to 128GB?
If I disassemble an iPad, is it possible to replace the internal flash mass memory with a 128GB Samsung SSD 1.8"? what is kind of the iPad's flash mass memory? does the quality of the internal multimedia decrease? Would iTunes support the modified iPad? Would I be able to install the iOS 4.2? Thanx for the answer.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from http://meta.ifixit.com/.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
No. The NAND flash is soldered to the main board, and it does not have an interface that's compatible with an SSD (or space inside for a drive).
It is hypothetically possible to replace the flash chips with larger capacity chips, but that would require a sophisticated surface mount de/soldering setup. In English: a semiconductor company could do it, but probably not an individual.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
There is a bunch of equipment on Ebay, for a 150$ which helps u to do it fast and easy. Depend on your will, and manual capabilities. Videos on facebook, and YouTube also. Approximately an hour job
von
Antwort hinzufügen
Francisco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 10,875
