Steering wheel wobble an steering block noises
Steering wheel started wobbling then ther was a nocking noise under bonnet everything is solid well maintained I think it's the steering block
Ist dies eine gute Frage?
shawnqueeley Its time to replace the steering fluid in the rack . This video will help https://www.youtube.com/watch?v=Iev1xIr3.... I cannot stress enough USE HONDA POWER STEERING FLUID. Regular steering fluid is too thick and will cause problems . Hope this helps
War diese Antwort hilfreich?
check your tires for bulges or uneven (snaky) tread, loose lug nuts, bent rims. Also check the steering fluid level and drive belt tension.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 218
