Tablet discharge within a few minutes some times.
Sometimes it takes hours to load the tablet completly and it even discharge while atached to the charging cable.
Ist dies eine gute Frage?
Replacing the battery should fix the discharge problem. Luckily, ifixit sells it.
However, if it doesn't charge well even after the battery replacement, your charging port/cable is bad or your charger isn't powerful enough. First, get a brand new Samsung cable. Not a flimsy one you would get at a convenience store. Also, make sure your charger is at least 2.1A 5v. If neither of those fix it, you'll have to replace the charge port.
Hope this helps!
War diese Antwort hilfreich?
Are you using the original charger?
Yes, I also tried another one and the same result.
But it doesnt happend every time.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 828
