Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Headphone amp is not working?
I have this Mac as my daily driver, and I regularly use the headphone jack. About a month ago there was crackling in the headphone jack only, and it has progressively gotten worse. It is not a grounding issue, since I've tried grounding the computer several different ways. The crackling is not present on powered devices like speakers, but for devices that rely on power from the port, like earbuds and headphones, the crackling is very noticeable. This has led me to the conclusion that the headphone amp is defective. Is this a board level repair?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
As long as you are sure it is not an issue with the devices you are plugging in, the issue will be with the headphone jack itself. Check inside to make sure there is no dust, since this will also cause crackling.
Replacing the jack is not easy, the part cannot be bought new either and has to be desoldered from another board. Call around to see if anyone will be able to replace this, but this type of repair is usually turned away by most repair shops.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
Couldn't it be a bad resistor or shorted cap attached to the jack lines? Or that would not cause crackling?
von
@rany if this was the case, I would have thought it would short the whole line to ground, meaning no sound. Whenever I have seen headphone crackle (Macs, iPhones, iPads, etc) it has been resolved by replacing the headphone jack. The jack itself is grounded through the soldering to the board, so I don't think it is a grounding issue either.
von
Thanks @reecee, I don't have much experience with headphones jacks, haven't seen them much, so I'm asking.
von
@rany I haven't had a lot for headphone issues before either, usually just work on them ones as an extra on top of another repair, I don't like to get these in just for headphone issues, they are not fun :/
von
Antwort hinzufügen
Seji the veggie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 378
