Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Home button getting hot
Hi guys.
I did look to see if anyone had had this issue with an iPhone 6 before the other thread i think they were referring to a 6S.
OK i have just had a phone come in for a screen repair their child had smashed it off a wall & the screen was shattered but also the home button had been torn off too.
I have replaced the screen but any home button it try gets so hot you can't touch it i have tried both genuine recycled from other iPhone 6 & i have also tried aftermarket brand new ones all with same result.
I have had this once before but it was my bad as i had used a 6S home button on a 6 & this got hot just the same as this one.
Any ideas please?
Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
& no i have checked this time it is 100% an iPhone 6 home button not a 6s
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try another home button extension cable (You can buy them with the back metal plate together [personally i prefer this] or separately).
Also check the home button extension cable connector on the logic board.
The part looks like this:
iPhone 6 LCD Shield Plate with Sticker and Home Cable
iPhone 6 LCD Shield Plate with Sticker and Home Cable Bild
Produkt
War diese Antwort hilfreich?
Bewertung 3
i tried this but it’s still hot. any other solutions?
Bewertung 0
1 Kommentar:
Forgot to mention, if this still does not help you can try replacing the home button but touch ID wont work as a tradeoff.
von
Antwort hinzufügen
Kenny Leonard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 2,493
