Battery indicator always 100% mark after replace battery
Hello,
After changing the battery of the iphone, the battery indicator always 100% mark. I restored the iphone, I've done a hard reset and still the same. Any ideas?
Thanks in advance.
Ist dies eine gute Frage?
3 Kommentare
Iban how long have you used the phone on battery power to see if the display moves? Try to use it for as long as you can to see if that will make a change. Do you have any other issues with the phone?
von oldturkey03
I've used it until the battery runs out, all day. Before going off continues to lead 100. I plugged in to charge several times and still says 100%. Everything else is working properly.
von Iban
I'm having the same problem. I replaced the battery on my 3GS. After replacing it it initially showed a charge of 45%. I continued to use it until it went down to 26% but then plugged it in overnight. In the morning it was at 100% but it's been at 100% for the whole day. Any other options besides replacing the battery again?
von ckuweb
