Zum Hauptinhalt wechseln
Quit working wont turn on
Conair bonnet hair dryer only 3 months old quit working
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
My Conair hair dryer stopped working, should I send it back to the company
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Suzy Cory, Try another known working outlet. If no go, more then likely has a one year warranty on hair dryer and you may want to consider contacting the manufacturer for repair/replacement/refund. If not you could disassemble the hair dryer and test/check all connections, cord/plug, switch, if fused check, with a DVOM to see if faulty. Below is a guide to disassemble various models that may help. If not wanting to work on the dryer yourself perhaps have a good local small electronics shop have a look, diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Hair Dryer
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Looks like we were answering this at the same time.
von
mayer, yes, been a while since it had happen :-)
von
Hilfreichste Antwort
It is covered under warranty. First try returning it to place of purchase.
That failing, register it here, then request a warranty repair:
https://www.conair.com/co/101e94/product...
Bewertung 2
If it experienced a reduction of airflow, you might have tripped the safety fuse on the heating element.
Bewertung 0
Antwort hinzufügen
Suzy Cory wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 78
Insgesamt: 10,251
