Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
552 Fragen Alle anzeigen
a1502 dead logic board
Hello Guys
Macbook Pro Retina A1502
COMPLETELY DEAD
No water damage, it simply didn't turn on again.
MagSafe is working normally.
However I think I should go over the power rails to fix this BOARD, right?
Is there anyone that can me give the next steps here?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Find power aliass on your schematic, start testing power rails, I would start with pp3v3_g3h. You will want to use process of elimination, by that I mean find what power rails you have and what are missing, then work your way backwards to find the source of the issue. Remember when testing rails don't go from A to Z, start with point A then test point Z , then point B then point y and so on till you find the issue.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@triomacrepair
Still looking for your answer about REMOTE logic board repair tutoring.
Anyways.
I will go A to Z, cause at NOW my mind cannot understand why go to Z if B, C or D can give me the wrong voltage for example.
I mean, by logic, if B is an ISSUE the rest of the BOARD will be giving me wrong values. I guess so!
Forza if possible reach me by WhatsApp +55 53 9 9705 9883
Thanks!
von
Antwort hinzufügen
Angelo Recaman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 594
