Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
My iPhone 7 will not stay on
Hello,
About a month into having a brand new iPhone 7 i had dropped it an cracked the screen a little. When I'm using it the part where the screen is broken lights up differently. You can tell something is wrong. I went a few months like that and ended up dropping it again. Days went by and my phone would turn off around 40% then 60% and now it won't stay on for more then 10 seconds without being on the charger. It doesn't have the powering off spinning circle when it turns off it goes completely black. I don't know if i should replace the screen or if its something else. I don't wanna spend unnecessary money on the wrong things. please help. Is it the LCD cord detaching or is it my battery??? I'm so clueless. Also if the top left side of phone it looks like its coming up a bit.
another thing is iv only had this phone for 6 months.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
I hope you mean LCD Cord...
von
lol yes idk why i even put LSD I'm such a dummy sometimes
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Battery needs replacing and the display is recommended to be replaced as you will need to lift up the screen to get to the battery.
I recommend getting it repaired by apple (Approx $129 USD so it's a no brainer) as the good replacement screens are quite expensive.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
would you know how expensive it would be if i took it to apple?
von
My guess would be around $349 USD.
von
Last I checked iPhone 7 plus repairs at Apple are $140? Gonna go there in the next couple days. I'll ask. I'm thinking the damaged display is now over drawing the current from the battery
von
I was basing prices off the original replacement screen price online.
It's probably cheaper from apple store.
Apple website says $129 USD that's good and cheap.
von
thank you i will take it in today
von
Hilfreichste Antwort
It is probably the Screen Assembly. If it is flickering and not functioning properly, that is a strong indicator of LCD Malfunction. However, from the issues you describe, it could also be the battery, or even a combination of the 2.
Bewertung 3
Maybe the LCD start giving up. You should replace the LCD first, if issue dont go away then check the battery.
Bewertung 1
Antwort hinzufügen
sabrina wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 3,048
