Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
20 Fragen Alle anzeigen
Is the grey connector cap important?
I broke two "tooth" from the digitizer connector CAP (the grey thingy) while trying to change it. is it why my new digitizer doesn't work too ? or is the new one also damaged because I see some scratch on the ribbon cable... ?
thank you all :(
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If the latches on the motherboard are damaged, you can always try applying pressure while turning the 3ds on, because that ensures that there is contact. If that works, you can put some paper or tissue in between the connector and housing to keep pressure on the connector
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
junnujs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 63
