Zum Hauptinhalt wechseln
Veröffentlicht am 24. Oktober 2011 / 2,2, 2,4, oder 2,5 GHz Quad-Core Intel Core i7 Prozessor
405 Fragen Alle anzeigen
Device booting to black screen
I restarted my macbook and just after the apple logo appeared there were some flickering lines on the screen and then just a row of vertical red lines. I turned it off and attempted to reboot it but now all that happens is the optical clicks and the front indicator light comes on. Otherwise it's just a black screen, no boot tone.
I attempted reseating the RAM, both slots, a PRAM, SMC reset, and manually removing the battery. I also booted it with no RAM in it and got the beep tones so I believe my logic board is alive.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Logic board has failed - based on the vertical lines and unable to boot.
Check out the last paragraph of this page: https://www.apple.com/support/macbookpro...
The late 2011 15" have known logic board issues and actually had a recall on them. Might be worth calling apple and seeing if they will replace it still even though they ended the program.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
It was discovered a tantalum capacitor was degrading that was the root issue. Apple placed it too close to the GPU so it tended to cook a bit. Review this answer: Problem with NVIDIA GeForce GT 330M 256 MB?
von
Interesting. Thanks for sharing!
von
Antwort hinzufügen
Dirk Gunderson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 424
