One side has no sound
One side has no sound. I have used the same sound source with other headphones and the problem is in the QC2 set. The cord has been replaced and the battery is new.
Ist dies eine gute Frage?
@marksorrels, it is possible that you have a bad driver (speaker) or a bad crossover cable. Remove the earpads,remove the Philips screws to get to the speaker. Use a multimeter to check from the cable end to the speaker cable connection and see if you have continuity. If you do, connect a temporary sound source to the speaker and see if it works. How can I fix the sound in the right ear? addresses the same issue on a slightly different model
War diese Antwort hilfreich?
Fantastic suggestion! I'll check it out on Saturday. Many thanks!
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 1,399
