mayer, The article you posted is excellent and the thing that attacks(fogging) the exterior plastic headlight lenses the most is probably exposure UV rays from the sun it self, I say this because I have noticed that garage kept cars/auto's seldom need headlights restored. Although there are other harmful stuff like sand/stone chips/acid rain/using Windex or other chemical cleaners not meant to clean plastics,etc. For instance some people like to drive in the draft of large trucks and in doing this the head lights/windshield/paint job are constantly being sand blasted with the debri off the roads. I do not CLR will remove the fogging as the top layer coating or of the plastic will have to be removed unless it is very,very light fogging. As for what is in the kits there is the common buffing compound as for the other wipes perhaps a silicone type substance I am not sure, may be on the label.
I have had success using the mothers type headlight restoration kit with the sanding pads/buffing wheel which attaches to drill, lens polish and sealer. The most important thing I have found was when using the power drill with attached polishing pad was to keep the RPM's down, keep pad a little damp(misting bottle/clean water) and keep it moving(do not run in one spot too long) or you could actually melt the plastic lens. If headlight is easily removable, I will do this sometimes to save from having to masking tape up paint job/ bumper/fenders/etc..
If fogging/scratches are not too severe, you can often get away with just polishing the lens after giving it a good cleaning with car soap. Some people I have noticed on you tube are actually putting a clear coat of enamel on their headlight lenses after doing the restore procedure(this may be iffy) as if you get a scratches there is a possibility you would may have to do extensive wet sanding to remove all the clear coat. I think just use a good compatible car wax in place of clear coat enamel.
So there you have it, if possible park car inside, park with head lights(front end close to a wall to shade from UV rays) and lights will stay good normally or you may have to polish them again in a couple years if left exposed to the outside environment.
https://www.youtube.com/watch?v=fvNSjjTH...
https://www.youtube.com/watch?v=NMz0Iyfv...
https://www.youtube.com/watch?v=a4xAoGO8...
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
