Zum Hauptinhalt wechseln
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
The canister is empty after I vacuum a room
When I vacuum a whole room the canister is empty. But the floor is somewhat clean
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
I am having the same issue. Have cleaned the vac from top to bottom twice, removed some clogs (cathair), took the vac apart and changed the filters. One clog was in the handle between the junction of the Suction Release coupler and goes backwards towards the hose connection. I cleaned that out and put it back together. After vacuuming again, the handle was clogged again, The vacuum is picking up, but when done, the canister is empty after vacuuming the room. I'm stumped. Can anyone help?
von
I am having the same exact problem!! My vacuum cleans and picks up the room, but the canister is empty! And the next time I go to use it it is not picking up so good, and so me and my husband take apart the vacuum and unclog the hose! We can not figure out why this keeps happening!!
von
I'm having this same issue along with it being extra loud!
von
I have this problem too. It seems to have a kind of block in place after the hose from the beater bar to the canister. The hose fills up with debris and not into the canister. After the hose fills up it starts falling back on the floor. I do have very good suction from the long hose. I was going to take it apart but thought I would check here first.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If your Shark Navigator Lift-Away Pro no longer sucks up dirt, dust, and debris, see the Shark Navigator Lift-Away Pro Loss of Suction problem page for possible causes and solutions.
If your Shark Navigator Lift-Away Pro no longer sucks up dirt, dust, and debris using the vacuum’s nozzle, see the Shark Navigator Lift-Away Pro Loss of Nozzle Suction problem page for possible causes and solutions.
War diese Antwort hilfreich?
Bewertung 2
Take off the brush on the bottom look underneath and also take it completely off of the vacuum itself and you will find your problem, or I did anyways
Bewertung 0
Antwort hinzufügen
tammy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 43
Insgesamt: 2,453
