Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1364 Fragen Alle anzeigen
Earspeaker/Earpiece not working after screen replacement iPhone 7 Plus
Hello Guys,
I have replaced a iPhone 7 plus screen. After the screen replacement the speaker above does not work anymore. Everything else is working, front cam, proximity sensor etc is all working.
I replaced also the speaker and the flex with new one, but without succes.
Who can please help me out of this problem?
Thanks a lot.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
did you try to put back the old speaker? what was the reason to change the flex and the speaker and not use the original ones?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Problem is fixed! It was a faulty front camera flex. We tried like 4 flex cables (with apple logo original), but only one worked.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
hope it is the same problem for me... Replaced an iPhone 7 Plus Cable Today and it got stock in the booting process, then took the original one, but now the earspeaker didnt work...
von
I believe I did the same thing today and all you had to do is barely hit the flex or cut it slightly I didn't even cut it what I did was is I somehow split it right at the part where the earpiece connects with 4 for gold pieces are,right at the right corner on the very corner I tried to lift it in the flex like split like basically when you peel off tape,going to try a new flex tomorrow and we'll see what happens
Bewertung 0
Here's a picture of the damage
Bewertung 0
Antwort hinzufügen
Nisay Atsu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 3,224
