Zum Hauptinhalt wechseln
A1418 / EMC 2833 / Ende 2015 / 3,1 GHz Core i5 oder 3,3GHz Core i7 Prozessor. Erscheinungsdatum 13. Oktober 2015.
96 Fragen Alle anzeigen
The cord joining from the power button to the logic board cut
Dear iFixit community,
I was in the process of upgrading my (iMac 21.5" 4k) and whilst I was removing the speaker (for easier access to SATA cable) the cord joining from the power button to the logic board (which travels along the left speaker) cuted. I was not applying much force and am very surprised that it broke. This means I am now unable to power up my iMac. Is there anything I can do to replace this part or somehow rejoin the wire? Any information would be GREATLY APPRECIATED!! (Even if it is "there is nothing you can do")
Thanks very much!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Please add some images so we can see what you do. Also which exact mode iMac do you have?
(Model number should be on the bottom of the stand.) Adding images to an existing answer
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If only a 2 wire cable was cut you can repair this the old fashion way: strip the wire at the end an redo the connection, if its to short ad some wire and be sure to isolate every wire at the joints.
Something like
If you have a soldering iron just resolder the wires
Something like this
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
ghmax2010 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 98
