Zum Hauptinhalt wechseln
How do I hook up to my 55 inch older tv?
I have S-video plug on my 55 inch older Toshiba and want to watch movies from Net Flicxs from my HP lap top Pavilion computer, what do I use for a cable?
Update (06/09/2017)
Toshiba 55"..HP Pavilion 1150us G series
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
What model is your tv and what model is your laptop. You might have other ports on the back of the TV that will work with no adapters.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
@mrsandiego you still did not tell us what model your TV is. Anyhow you are wanting to connect the S-video to the computer and the TV, so I assume that your TV at least has a S-video connection. Your HP Notebook seems to use a HDMI port as well as a VGA port. Check to see if your TV has that connector. If it does, get a VGA cable and simply connect it from your Notebook to your TV.
If your TV does not have a VGA port, you will need a HDMI-to-S-Video adapter. Of course, if your TV has RCA input you can simply purchase a HDMI-RCA video cable.
War diese Antwort hilfreich?
Bewertung 3
Looks like that laptop has a VGA and HDMI port, both of which are widely used in TVs. I can't say if your TV has either as I don't have the model, but if your TV doesn't have a VGA or HDMI port, you will need a VGA to S-Video adapter.
Hope this helps!
Bewertung 2
See it’s just showing a dim light
Bewertung 0
1 Kommentar:
How do I fix this? It has sound All the lights are working I replaced the main board So what do I do?
von
Antwort hinzufügen
AlBERT wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 185
