Zum Hauptinhalt wechseln
Das am 16. Januar 2009 online veröffentlichte Inspiron 1545 ist ein 15,6"-Budget-PC-Laptop, der mit 3 oder 4 GB RAM erhältlich ist. Es war der Nachfolger des Inspiron 1525.
beep sound dell inspiron 15-3521
Iam getting the same problem of beep sound dell inspiron 15-3521, but it is not stopping with 7 or 8 beeps it keeps on beeping, what should i do ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 7
7 Kommentare
7 beep or 8 beeps , both are different
von
When turning it on it beeps really loud. Then it stops after I sign in. Then after a minute it starts beeping softly but won't stop and I tried all this but nothing
von
My dell 3521 does not get started and beeps continously, four beeps in a period, with no display, what shold I do, please help.
von
Mine still beeps and screen will not come on so ita the motherboard then?
von
I am getting a long beep sound if the battery is attached to the system and my system is not getting started. I tried with your solution but it seems it is not working for me. Please help.
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
@gd27 continuous beep is usually a bad motherboard. So start off by getting rid of the static power by turning of the computer, remove the battery, ac adapter and the power cable. Press and hold down the power button for at least thirty. After that, reconnect the AC adapter and the power cable, then try to start it. If that did not work you can try and run the hardware diagnostics. For that shut down the laptop, press the FN key and then press the power button, Let us know what you get with this. It may also be beneficial if you connect an external monitor just to ensure there is nothing on the display. Let us know what you get after all of this.
War diese Antwort hilfreich?
Bewertung 9
13 Kommentare:
thanks a lot man , that was very helpful , my laptop is not beeping any more. i powered it on with FN key and after several colorful pages , it went on a checking menu . i clicked on hardware icon and after finishing the checking , reboot ........ everything work perfectly :)
von
Just the same thing I tried all the things and dos not work, any other thing that may work.
von
I tried the solution, it says no problems found. Still it continues beeping
von
I had to check the "thorough test" box, then click on the hardware icon as mentioned sobi (above). It still beeped until W8 booted, reset, then rebooted into itself. The beeping stopped during the final reboot. Thank you so much =)
von
It's still beeping and refused to on
von
8 weitere Kommentare anzeigen
Hi @Bhekumuzi Sindane
A 7 beep error code is a CPU failure. (Click on Table of Contents > 2. Dell Notebook Systems > Latitude to find the list of beep error codes and their meaning, pertaining to Dell Latitude laptops).
Since the CPU in your laptop is hard mounted on the motherboard this means that you will need a new motherboard
Bewertung 1
2 Kommentare:
My laptop can't stop beeping, everything is working except the beeping won't stop. How can I fix it? Pls. Help Me
von
@Mitchell Mangi
What is the make and model number of the laptop?
Is the beeping continuous or are there pauses between the beeps e.g. 5 beeps> pause > 5 beeps > pause > 5 beeps > pause etc?
When does the beeping start, before or after the laptop boots into Windows?
von
Check the CMOS sensor and change it if it is the problem. Mine had a similar problem , it will beep every time it boots found out CMOS sensor gone.
Bewertung 0
5 Kommentare:
But my laptop does not give display at all and keeps beeping
von
I have removed the battery and find the beeping stops intermittently. How can I find this sensor? Do you have the p/n for this sensor and offer a general location?
von
My computer gives out 3 continuous beeps when I turn it on but the screen is still black. I tried to remove ac cable and battery and held Power button for at least thirty, but nothing.
What do I do? It's a Dell Inspiron N5110
von
@rodrine kaputula
Beep Codes and Lights
https://www.dell.com/support/kbdoc/en-nz...
von
I have a Dell latitude 3540 it beeps 7 times and the screen is blank
von
Antwort hinzufügen
Theja wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 74
Insgesamt: 57,633
