Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
No Display and Repeating Charge Chime
Hello, I have 2 iPhone 4's on Verizon. I wanted to swap the screens on them since one is in locked and the other one is shattered. After a very long process of lost screws and frustration I finally have the good screen on the good phone. The only thing it does now is show up in iTunes and keep making the charge chime. I have put the other board in the housing and it does the same thing. I have even tried the cracked screen on both boards and the same thing happens. I would really appreciate it if you could help me out.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare:
Sounds like either board damage or both the screens got damaged from improper installation.
von
I have the same case, except my screen is shattered. The screen worked like that though, and my phone is a little rough, any fixes anyone?
edit: havent replaced the screen yet, its just like this
von
Einen Kommentar hinzufügen
1 Antwort
Very unfortunately, Dylan, your 'good screen' is probably bad. Exactly what you observe (no display and repeating chime) indicates a broken or missing screen. You have my sympathy: replacing iPhone 4 front/screen assembly is onerous. Too I broke an otherwise operational screen, by bending its cable.
See Wiki page: iPhone endlessly repeats the "power supply accepted" sound or vibration.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Dylan Mclaughlin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 59
Insgesamt: 727
