Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Why is my iPhone 5 constantly rebooting at high percentages?
My iphone jumps percentages. ( for example when it was off the charger it was at 87% plugged it in it goes to 90% unplugs it back to 87), (at 14-20% resets phone jumps to 70 when turned back on), ( staying on a percentage when on the charger and not moving.) Now it constantly reboots starting today. I ordered a new battery. Cleaned the battery connecter and charger port with 70% alcohol and cleaned the small corosion on the charger pins. Why does it keep restarting ? the screen turns grey for second then it restarts its on 82 and its constantly rebooting after being on for about a minute. Should I get a new charger as well with the new battery or is it another issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Did you unplug the battery before?
Sometimes the small components right above the battery connector get knocked off when you unplug the battery, especially happens when you accidentally pry under the battery connector instead.
This can cause incorrect reading of battery percentage for battery and random shut-off rebooting.
Most of the time it is just a bad battery if you have not replaced the battery before.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
I agree but this little snippet caught my attention "and cleaned the small corosion (sic) on the charger pins. "
von
70% alcohol on the charger cable pins and cleaned the charger port. The battery is about 3 months old but I'll see how the new one goes. Hasn't restarted yet
von
I suspect your battery is reaching EOL,
Bewertung 1
It could be battery problem. But may I know what is your iOS version?
If you are on iOS 10+, your device may reboot usually. Your device could not support iOS 10 or higher firmware very well. So it is normal when your iPhone 5 often reboots on a high iOS version.
Bewertung 0
2 Kommentare:
I Was on 10.3.1 because 10.3.2 kept on making my battery drain but I just went back to iOS 10.3.2
von
If your battery is fine, then I think it is normal, my iPhone 6 sometimes reboots on iOS 11.
von
Antwort hinzufügen
dj holley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 128
