Zum Hauptinhalt wechseln
Eine programmierbare Kaffeemaschine von Keurig. Diese Kaffeemaschine verwendet K-Cup-Kapseln und K-Carafe-Kapseln, um eine Vielzahl von heißen und kalten Getränken zuzubereiten. Modellnummer: K2.0-400 Seriennummer: 401.0200.1410931
Piece of rubber hanging down from needle
My Keurig 2.0 is working but there is this little rubber piece that is hanging off from the top. It is a straight piece that then ends in a little rubber circe. The circle is broken.
My daughter is planning on taking it to college with her in September and I was wondering if I can fix this little piece some how.
Update (06/29/2017)
This is a picture from under my machine
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Answer is related to the mini-pump, but the question is about the needle seals.
von
this looks like a black rubber washer. Why can't I find them anywhere?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
This is the seal washer for the needle. I don’t recall why there’s two parts to it. I think mine only has one. It seals between the machine and the top of the pod.
This might work to fix it: https://www.amazon.com/Replacement-Needl...
https://www.bonanza.com/listings/Keurig-...
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
The item from Bonanza should work since my Keurig is a 2.0 K400. The part is a little pricey, but it's cheaper than a new Keurig. I also don't know about the 2nd attached piece, but I guess I will find out! I will order this and keep you posted. Thank you for all your help in locating this part.
von
@willpsree thanks for posting the link excellent find since those O-rings have a tendency of disappearing!
von
This guide shows you the tubing:
Keurig 2.0-400 Mini-Pumpe austauschen
Bewertung 1
Antwort hinzufügen
Phyllis Jozwik wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 37
Insgesamt: 10,989
