Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1488 Fragen Alle anzeigen
iPhone gives 1002 error syncing, possible cause the dock connector?
My sister-in-law handed me her iPhone stating that she spilt bottled water on the bottom, the phone charges fine, will only go into recovery mode.
iTunes updates the phone, but about 1px away from finalising the firmware update it times out after about 10 minutes giving a 1002 error.
Opening the phone just to reveal components does not show any evidence of water damage or corrosion, I don't know how much water she thinks actually got in there.
I'm suspecting (hoping) that replacing the dock connector might resolve the issue, could anyone suggest if this is a wise move or could the phone be completely lost?
At the end of the log file I see the following:
Sending EBL Loader...
    Sending EBL Loader Length...OK
    Sending EBL Loader Data...OK
    Sending EBL Loader Checksum...OK
Sending EBL Loader -- All OK
Sending EBL...
Timed out
Giving up
!!! Exception at :0:
    - BBUReturnTimedOut(10)/2: Receiving EBL Loader ready indication failed
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
http://www.hackint0sh.org/f127/4591.htm has a lot of info about this issue I have not come across anything that suggested to replace the dock connector. Here is what apple says http://support.apple.com/kb/TS1275 What I did found was something like this "1. Download Quickpwn 2.2
2. Open Itunes, try to restore
3. Get the 1002 error
4. Open Quickpwn
5. A popup should come up saying that you need to restart your Iphone/Ipod
6. Follow the instructions
7. When you see the Apple boot logo close Quickpwn
8. Your Iphone/Ipod should boot up normally and itunes will recognise it as a new iphone/ipod"
Quickpwn is at http://www.quickpwn.com/ and I am of course not suggesting to unlock or JB your phone. But give it a try before replacing any parts.
http://www.sinfuliphone.com/showthread.p... some more suggestions. Good Luck to you and your phone
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
iReb is only available for windows...boo if you've got a mac!
von
I am so sorry I forget about the mac....promise I will get used to checking for the mac as well.
von
just found this at http://forum.gsmhosting.com/vbb/f456/itu... Error 1002
Are you restoring to a stock apple firmware or a custom pwn firmware? Either way make sure you are in DFU mode first. http://osxdaily.com/2010/06/24/iphone-df... and http://limitededitioniphone.com/how-to-p...
von
Ah such a bugger, still can't seem to get it to update, I ended up trying PwnageTool 4.1.2.
I tell you it gets darn hopeful when you see it get to 1px left before completing and then it sits there for 10 minutes, lol.
von
Hi Brett,
That's the terrible thing about water damage; it could be in a pool for ten days and work fine after or 1 drop could end it.
If you ever get the iPhone to turn back on, and it just goes through a reboot cycle or connect to itunes, it's pretty much a lost cause. (UNLESS THE ABOVE WORKS...) We have tried so many times to fix a water damaged iPhone with these symptoms, and the only thing that works is replacing the logic board ($300 and up).
Please don't shoot the messenger.. we are only here to help!
Best,
Charlie
Bewertung 2
1 Kommentar:
Thanks Charlie, I think I might have to tell her it's not going to work anymore, maybe I will now know what to buy her for her birthday this year now, lol.
von
Thanks both of you guys for your help, I did read some forums suggesting the quickpwn thingy but it seemed to crash and not do anything, though when unplugging the phone it said something along the lines of "great, you're iPhone has been jailbroken", but restarting kept putting it in that pesky recovery mode.
I'll give it another try again tonight, but if it doesn't work I'll just assume the bugger is dead, a shame really, it's pretty new.
Bewertung 2
2 Kommentare:
Brett, it's not dead its just hibernating, don't give up on it yet I bet someone one here is going to find the solution :)....
von
I won't give up (entirely), lol as I was saying to my missus earlier "you know, I'll still be fighting with this bugger in 6 months when it's her birthday and I'll just buy her a new one or something and still continue to fight with it" lol
von
Hi can some one me out?i have a iphone 3gs and wanted to unlock it i could not unlock when i wanted to restore it,i could not i keep get error 1002 any time i try it so if any one can help me out.thanks
Bewertung 0
Antwort hinzufügen
Brett Ryan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 5,192
