Zum Hauptinhalt wechseln
The LG K7 is smartphone released by LG in February 2016 and runs on Android 5.1.
89 Fragen Alle anzeigen
How to fix the unresponsive touch screen on my lg k7?
All of sudden the touchscreen on my lg k7 phone completely stopped working and I tried to do a factor reset on it and now its stuck on the factor reset part and wont let me get past that point!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
when you do factory reset sometime it takes longer time to startup need about 5 minutes and don't interrupt the process or you can stuck in bootloop if that happen try flashing your phone.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I don't understand what you mean with flashing my phone?!? And I didn't interrupt the process of it been done but with my touchscreen not working my phone is now stuck on the restarting starting part! I'm suppose to be able to touch the next button and I'm not able to do that because of the simple fact that my touchscreen isn't working at all.
von
stuck on restarting when phone start it called bootloop and flashing procedure it mean reinstall os (android) into the phone, you need pc/laptop and usb cable data also software to flash the phone
von
Why is my touch doesn't work when i use two fingers on the screen? and there is a ghost touch happening too
von
Antwort hinzufügen
yaraandpayton2007 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,568
