Zum Hauptinhalt wechseln
Drucker, Scanner Kopierer in einem Gerät. Eine Baureihe von HP.
31 Fragen Alle anzeigen
Why is my ink carridge not moving after a paper jam.
My printer was working fine but then had a paper jam. Removed jam but printer is not aknowledging this and the print cartridges wont move even manually. Can anyone help please as can't afford a new one? thanks.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
How can I overcome the problem?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I'm not familiar with your printer, but I work with large format machines.
First off, It's important not to force the print carriage (the part that holds the print heads) as this could damage the belt that attaches to the motor or the motor itself.
As a first step, you can always turn both the printer and the computer all the way off and then back on. While the printer is off, unplug it and hold the power button for about 10 seconds. Not sure if it matters but I turn on the computer first, then the printer. That way I can make sure there is nothing in the print queue.
If that doesn't work, The manuals usually have troubleshooting for this kind of problem in the back section. There is usually something like a maintenance cartridge or other device that is keeping the motor engaged and will keep the print heads from being moved.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I have done this but got no result
von
Should I open the printer ?
von
Antwort hinzufügen
doddsarah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 373
