Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Ho avuto lo stesso problema, ero convinto fosse un problema di software, ma era semplicemente la camera guasta. Sostituita con nuova camera, ora tutto funziona perfettamente , messa a fuoco compresa.
you must have updated your firmware/OS, if so, try rolling back. This is a known issue with H P8. unless its something else in which case bring it to a service center.
Have you tried flicking it?
von S W
Because the camera is broken
von Big boy
von ALEX FRANCESCHI
