Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
Touchscreen ist not reacting, sometimes
Hey guys,
I have a problem.
After I restarted my iPhone 5c I had first some little truble with the touchscreen. Sometimes it was not working (touch) and sometimes I worked fine. Display was always okay, only touch had problems.
Then it got worse and the periodes of working touchscreen got smaller. I replaced it in the store, it worked and 1 day later, again it started not do work.
I paused using the phone for some days, put back the old screen (also been replaced 1/2 year ago) and it worked 2 days. Right now, again, its not working for most of the time.
Might it be someting like a loose connection? I checked the connector for the digitizer by eye. Everything looks all right.
What could it be? Cause I changed the display, with the cables and it also didn't work.
You'd do me such a favour helping me.
Thank you so much,
Leo
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
1. Is the coloured frame of your 5c in good condition? the touch can sometime play up if there is to much pressure on parts of the screen due to damage to the coloured frame. (you can buy new frames if yours is damaged)
2. Is the software up to date? Is the phones storage full? make sure its updated and free up some space if you have less then 1GB free, then try backing up then factory resetting the phone.
3. If there is still a problem i would say you have bad quality screens and a new original or good quality replacement should fix the problem.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hi,
1. The problem also appears when I test the display out of the frame.
2. Yes, its up to date, also I resetted the phone. And checked the storage.
3. The store I gave it to, put on a original screen. But it didn't help.
Crazy, seems like a loose connection at the logic board I guess.
von
Antwort hinzufügen
Leo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 59
