Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
95 Fragen Alle anzeigen
No display after battery replacement
A customer brought the device to me saying it needed a battery. Device showed no signs of life.
I replaced the battery. The logic board heated up but no picture. Also, i did this repair without removing the front panel assembly.
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Try another screen, known working charger battery?
Also does it detect via computer in iTunes in case of a no backlight issue?
von
I tried an authorized charging and nothing. I thought about trying another screen. I'll give them the option because they bought it from someone else so there's no telling what prior issues that it had.
von
But still no picture
von
Einen Kommentar hinzufügen
4 Antworten
I would suggest disconnecting the front panel assembly while replacing the battery. Then try booting your device up with the new battery. If it does not turn on or show signs of functionality, I would look into replacing the logic board.
War diese Antwort hilfreich?
Bewertung 0
Maybe it gone in DRY mode try to connect with itunes... then unique option is restore
Bewertung 0
Do you notice this:"The logic board heated up ", what happened to it?
Bewertung 0
Yes the logic board did heat up quite a bit
Bewertung 0
Antwort hinzufügen
The Wizard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 113
