Zum Hauptinhalt wechseln
Die Xbox Spielkonsole der dritten Generation von Microsoft kam am 22. November 2013 auf den Markt;
727 Fragen Alle anzeigen
Xbox One shutdow itself after a 3 seconds of startup
I have this problema with my Xbox one. With all then component disconnected. I connect HMDI (TV OUT), connect power brick to the wall socket. In this point I get orange light. Then Connect cable to the console, I get white light (1 second later) then yellow.
In this point all seems to normal. When I startup (using controller or press xbox botton console) the xbox one, after a few seconds (2 o 3) the console shutdown itself. No light on console and no light on power brick.
It this point power brick seems to be death. I have to disconnect from wall socket wait 5 seconds and then reconnect in order to get again a orange light
I would appreciate any help you can give me
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hi Aracely!
Have you tried plugging the Xbox One's Power Supply into a different outlet? If that does not work, I would recommend getting a replacement power supply. From what you have described, the issue is most likely a bad Power Supply or bad outlet.
War diese Antwort hilfreich?
Bewertung 0
Did you get a new power brick and if so did it work I am having the same problem as you and Inam worried that my console is broken.
Thanks
Bewertung 0
Antwort hinzufügen
Aracely Medrano wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 498
