Zum Hauptinhalt wechseln
PlayStation 3 wireless LED controller made by Performance Designed Products, LLC with model no 064-015-EU-BL.
USB Not connecting to PS3
My PS3 afterglow controller has always worked great but recently the USB drive just stopped connecting. Now whenever I plug in the USB to my system it just continuously blinks. My USB ports are working fine because I can still charge other controllers and the actual USB to the controller connects perfectly fine to my PC just not my PS3. So I have no clue what the issue is and I don't quite want to get a new controller yet because it seems like this one still works, it just isn't connecting to my PS3 right now. It'll be great if someone could answer this
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
how u dont use the usb for ps3 and pc
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Check the pins on the controller's end of the USB. Are any of them bent or dirty? A short due to a bent pin or dirt blocking a connection could be causing the issue. It also would not hurt to give the controller's usb pins a cleaning with contact cleaner to ensure a clean connection. I would also recommend checking the cable itself, to see if their are any kinks in or exposed wiring. If that doesn't it fix it, then its most likely a problem within the controller's PCB board.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
What is a pcb board and how can i fix it or clean it so i can get the controllers to work
von
Antwort hinzufügen
Ty Smothers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 34
Insgesamt: 12,556
