stop firing no battery light on dashboard
my car just stop running i check all the fuse all are good all lights on dashboard except battery light no current going to the coil what else can i check
Ist dies eine gute Frage?
Check your battery with either a voltmeter of, better still, with a battery checker. Voltage should be about 13V if your battery is healthy. Use a battery booster. If your car starts then either the battery is dead or your alternator does not charge it. If you manage to start your engine measure voltage at the alternator output terminals; it should be over 14 Volts.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 781
