Zum Hauptinhalt wechseln
Repair information and disassembly guides for laptops manufactured by Haier.
114 Fragen Alle anzeigen
Why my laptop takes alot of time when switched on?
when i switched on my laptop it takes alot of time. i am facing this problem from last week. and the time of switching on is increasing time to time. now it takes 16 minutes after pressing the switch on button???
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Hi @osama17201, check if your HDD is failing.
Use a HDD diagnostic to check your HDD.
Some laptop BIOS key / etc have an option to check the HDD.
von
how it will be checked???
von
Einen Kommentar hinzufügen
1 Antwort
Do a Clean boot, and if the system boots faster than usual then there is a start up program causing the system to hang
To perform a clean boot:
1.Press the Windows + R key and enter msconfig in the search box and hit enter
2. System configuration window will open, now go over to the services tab and check the box at the bottom that says "hide all Microsoft services" then click disable all, now click apply
3. Go over to the start up tab and click disable all and click apply followed by OK (if you are on windows 10 you will have to go to task manager to view the start up items but you do the same and disable all)
4. you will now be asked to restart, once you restart if the system boots faster then you will need to either disable all your startup programs or go in and enable them 1 by 1 to find the culprit.
5. Once you're finished troubleshooting go over to the services tab and click enable all and hit apply and restart.
Can you also share your model number or system specs
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
osama wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 184
